This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this task to configure Auto-sense data traffic information for ports that are operating in Auto-sense mode.
Configuring the Auto-sense data I-SID:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense data i-sid 1000
The following table defines parameters for the auto-sense data command.
Variable |
Value |
i-sid <1-16777215> |
Specifies the service instance identifier (I-SID). |
