Creating an IPv6 ACL
Create an IPv6 ACL to specify an ordered list of ACEs, or filter rules.
You must specify the packet type as IPv6 at the ACL level to enable IPv6 filtering. By default, an ACL filters non IPv6 packets.
You cannot change packet type for the ACL once you have configured it. If you want a different packet type, you must delete the ACL and re-create it using the other packet type.
Application Telemetry must be disabled on Extreme Networks Virtual Services Platform 4000 Series, 7200 Series, and 8000 Series.
Variable definitions
Use the data in the following table to use the filter acl command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
enable |
Enables the ACL state, and all associated ACEs. Enabled is the default state. |
matchType <both|terminatingNNIOnly|uniOnly> |
For inVsn ACL types, specifies the match type to associate with
the ACL. Valid options are:
name WORD<0-32> |
Specifies an optional descriptive name for the ACL. |
type <inVlan|inPort|outPort|inVsn> |
Specifies the ACL type. The values inVlan, inPort, and inVsn are ingress ACLs. The value outPort configures IPv6 egress filters. IPv6 ingress and egress QoS ACL/Filters are not supported. A port-based ACL has precedence over a VLAN-based ACL. |
pktType <ipv6> |
Specifies the IP version as IPv6. The default is nonipv6. Note:
You cannot change packet type for the ACL once you have configured it. If you want a different packet type, you must delete the ACL and re-create it using the other packet type. |
