Use the following procedure to configure the aging time globally for the forwarding database.
Variable definitions
Use the data in the following table to use the mac-address-table command.
Variable |
Value |
aging-time |
Specifies the timeout period for dynamically learned mac addresses on the vlan. The default valus is 300. |
<10–1000000> |
Specifies the range for the aging time. |
