Use the show sys power command to view a summary of the power information for the chassis.
The syntax for this command is as follows.
show sys power [global] [power-supply] [slot]
The following example shows sample command output.
Switch:1#show sys power
Chassis Power Information
Chassis Power Status: redundant
Total Required Max
Chassis Chassis Redundant Allocated Available Reserved Required
Type Power Power Power Power Power Power
SwitchXYZ 4200 1400 1851 2349 1411 1851
Power information can differ by hardware platform. For more information, see the hardware documentation for your platform.
