Use ACE Ethernet port entries so that the filter looks for traffic on specific ports. You can only insert an ACE Common Ethernet port for VLAN ACL types.
The ACL exists.
The ACE exists.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click Eth.
- Click the Port tab.
- Click Insert.
- Specify the operation type.
- Click the Port ellipses (...).
- Choose the ports.
- Click OK.
- Click Insert.
Port field descriptions
Use the data in the following table to use the Port tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq parameter specifies an operator for a field match condition: equal to. |
Port |
Specifies the port or port list on which to perform a match. |
