Use this procedure to enable IPv6 alternative routes and view the configuration on the switch.
enable
configure terminal
Optional: router vrf WORD<1-16>
ipv6 alternative-route
IPv6 alternative routes are enabled by default.
show ipv6 global [vrf WORD<1–16> | vrfids WORD<0–512>]
show ipv6 route alternative [vrf WORD<1–16> | vrfids WORD<0–512>]
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf globalRouter Switch:1(router-vrf)#ipv6 alternative-route
Switch:1#show ipv6 global
IPv6 Global Information - GlobalRouter
forwarding : enable
default-hop-cnt : 64
number-of-interfaces : 0
icmp-error-interval : 1000
icmp-error-quota : 50
icmp-unreach-msg : disable
icmp-addr-unreach-msg : enable
icmp-port-unreach-msg : enable
icmp-echo-multicast-request : enable
static-route-admin-status : enable
alternative-route : enable
ecmp : disable
ecmp-max-path : 1
source-route : disable
host-autoconfig : disable
Switch:1#show ipv6 route alternative
IPv6 Routing Table Information - GlobalRouter
Destination Address/PrefixLen NEXT HOP VID/BID/TID PROTO COST AGE TYPE PREF
2910:0:0:1:0:0:0:0/64 fe80:0:0:0:b2ad:aaff:fe42:dd00 V-3 OSPF 2 0 B 20
2912:0:0:1:0:0:0:0/64 0:0:0:0:0:0:0:0 V-1001 LOCAL 1 0 B 0
2912:0:0:1:0:0:0:0/64 0:0:0:0:0:0:0:0 T-10 BGP 1 0 A 45
3000:0:0:1:0:0:0:0/64 0:0:0:0:0:0:0:0 V-3 LOCAL 1 0 B 0
4001:0:0:1:0:0:0:0/64 0:0:0:0:0:0:0:0 T-10 LOCAL 1 0 B 0
5910:0:0:1:0:0:0:0/64 0:0:0:0:0:0:0:0 T-10 BGP 1 0 B 45
5910:0:0:1:0:0:0:0/64 fe80:0:0:0:b2ad:aaff:fe42:dd00 V-3 OSPF 2 0 A 120
5910:0:0:2:0:0:0:0/64 0:0:0:0:0:0:0:0 T-10 BGP 1 0 B 45
5910:0:0:2:0:0:0:0/64 fe80:0:0:0:b2ad:aaff:fe42:dd00 V-3 OSPF 2 0 A 120
13 out of 13 Total Num of Route Entries displayed.
TYPE Legend:
A=Alternative Route, B=Best Route, E=Ecmp Route
