Display information about flap-dampened routes to determine unreliable routes.
The following table defines parameters for the show ip bgp dampened-paths command.
Variable |
Value |
{A.B.C.D} |
Specifies the source IP address in the format a.b.c.d. |
longer-prefixes |
Shows long prefixes. The longer-prefixes indicate the mask length from a specified prefix to 32 (for example, show from prefix a.b.c.d/len to a.b.c./32). |
<prefix/len> |
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
Job Aid
Use the data in the following table to understand the show ip bgp dampened-paths command output.
Field |
Description |
NETWORK/MASK |
Specifies the network IP address and exact mask length (must be an integer value from 0–32). |
PEER REM ADDR |
Specifies the IP address of the remote peer. |
NEXTHOP ADDRESS |
Specifies the IP address of the next hop. |
ORG |
Specifies the source of a route:
LOC PREF |
Specifies the local preference. |
