Use statistics to help you monitor OSPF performance.
View the OSPF interface statistics:
Switch:1#show ip ospf ifstats
OSPF Interface Statistics - GlobalRouter
---HELLOS---- ---DBS--- -LS REQ-- --LS UPD--- -LS ACK---
INTERFACE RX TX RX TX RX TX RX TX RX Tx
192.0.2.3 428 431 0 0 0 0 0 0 0 0
192.0.2.11 1454 493 14 13 4 5 66 54 58 3
Variable definitions
The following table defines parameters for the show ip ospf ifstats command.
Variable |
Value |
<1-4059> |
detail |
Displays the details of the OSPF. |
mismatch |
Specifies the number of times the area ID is not matched. |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
