Perform this procedure to delete the configuration of specific IPsec tunnel on Fabric IPsec Gateway Virtual Machine (VM).
Deleting the authentication key and tunnel name configured on IPsec tunnel with ID 2:Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> delete ipsec 2 auth-key FIGW> delete ipsec 2 tunnel-name
The following table defines parameters for the delete ipsec command.
| Variable | Value |
| <1-255> | Specifies the unique ID of the configured IPsec tunnel. |
| admin-state enable | Disables the IPsec status on the specific IPsec tunnel. |
| auth-key | Deletes the authentication key that you configure on the specific IPsec tunnel. |
| encryption-key-length | Resets the encryption key length for the specific IPsec tunnel to its default value, that is 128 bit. |
| fe-tunnel-dest-ip | Deletes the destination IP address that you configure on the Fabric Extend (FE) tunnel. |
| ipsec-dest-ip | Deletes the destination IP address that you configure on the IPsec tunnel. |
| mtu | Resets the Maximum Transmission Unit (MTU) value for the specific IPsec tunnel to the MTU value configured globally. |
| responder-only | Deletes the mode that you configure for the IPsec session in FE tunnel. |
| tunnel-name | Deletes the name that you configure for the IPsec tunnel. |
