This procedure does not apply to VSP 8600 Series.
Use this task to configure static routes for the management VLAN.
- Expand Mgmt Instance.
- Select Mgmt.
- Select the IpStaticRoute tab.
- Select Insert.
- For the Instance, select vlan.
- Type the destination IP address and mask.
- Type the next hop IP address.
- Type a metric value.
- Select Insert.
IpStaticRoute Field Descriptions
Use the data in the following table to use the IpStaticRoute tab.
Name |
Description |
Instance |
Specifies the Management Instance. |
DestAddr |
Specifies the destination IP address. |
DestMask |
Specifies the destination mask. |
NextHop |
Specifies the next hop address for the static route. Use an IP address in the same subnet as the management VLAN IP address. |
IntfName |
Specifies the Management Instance interface name for the route entry. |
Metric |
Specifies the static route cost. The default is 200. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100. |
State |
Shows if the route is active or inactive. |
