Use the show ipv6 mroute interface command to display the IPv6 mroute interface information. The syntax for this command is as follows.
Switch:1(config)#show ipv6 mroute interface
Mroute Interface - GlobalRouter
INTERFACE TTL PROTOCOL
VLAN 2 1 pimsm
VLAN 7 1 pimsm
VLAN 10 1 pimsm
VLAN 20 1 pimsm
4 out of 4 total mroute entries displayed
The following table shows the field descriptions for this command.
Field |
Description |
INTERFACE |
Displays the slot and port number or VLAN ID for this entry. |
TTL |
Displays the datagram time-to-live (TTL) threshold for the interface. IPv6 multicast datagrams with a TTL less than this threshold are not forwarded out of the interface. The default value of 0 means that all multicast packets are forwarded out of the interface. |
PROTOCOL |
Displays the protocol as one of the following:
