Use the following options to display Layer 3 VSN with IP Multicast over Fabric Connect information to confirm proper configuration.
  1. To enter User EXEC mode, log on to the switch.
  2. Display all the VRFs that have MVPN enabled and their corresponding forward cache timeout values:
    show ip vrf mvpn
  3. Display IP Multicast over Fabric Connect route information:
    show isis spbm ip-multicast-route [all][detail]
  4. Display IP Multicast over Fabric Connect by group and source address:
    show isis spbm ip-multicast-route [group {A.B.C.D}][detail][source {A.B.C.D}]
  5. Display IP Multicast over Fabric Connect route information by VRF:
    show isis spbm ip-multicast-route [vrf WORD<1–16>] [group {A.B.C.D}]
  6. Display IP Multicast over Fabric Connect route information by VLAN:
    show isis spbm ip-multicast-route [vlan <1-4059>][detail][group {A.B.C.D}]
  7. Display IP Multicast over Fabric Connect information by VSN I-SID:
    show isis spbm ip-multicast-route [vsn-isid <1–16777215>][detail][group {A.B.C.D}]
  8. Display summary information for each S, G, V tuple with the corresponding scope, Data I-SID, and the host name of the source:
    show isis spb-mcast-summary [count][host-name WORD<0–255>][lspid <xxxx.xxxx.xxxx.xx-xx>]
Display Layer 3 VSN with IP Multicast over Fabric Connect information:
Switch:1>enable
Switch:1#show ip vrf mvpn
                              Vrf name : green
                                  mvpn : enable
                     fwd-cache-timeout(seconds) : 210
                              Vrf name : 4
                                  mvpn : enable
                              Vrf name : blue
                                  mvpn : enable
Switch:1#show isis spbm ip-multicast-route all
              SPBM IP-multicast ROUTE INFO ALL
Type   VrfName Vlan Source     Group        VSN-ISID  Data ISID BVLAN Source-BEB
               Id
routed GRT     501  192.0.2.1  233.252.0.1  5010      16300001  10    el2
routed GRT     501  192.0.2.1  233.252.0.2  5010      16300002  20    el2
routed GRT     501  192.0.2.1  233.252.0.3  5010      16300003  10    el2
routed GRT     501  192.0.2.1  233.252.0.4  5010      16300004  20    el2
routed GRT     501  192.0.2.1  233.252.0.5  5010      16300005  10    el2
routed GRT     501  192.0.2.1  233.252.0.6  5010      16300006  20    el2
routed GRT     501  192.0.2.1  233.252.0.7  5010      16300007  10    el2
routed GRT     501  192.0.2.1  233.252.0.8  5010      16300008  20    el2
routed GRT     501  192.0.2.1  233.252.0.9  5010      16300009  10    el2
routed GRT     501  192.0.2.1  233.252.0.10 5010      16300010  20    el2
Total Number of SPBM IP multicast ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vrf green
				  SPBM IP-MULTICAST ROUTE INFO
Source       Group         	Data ISID  BVLAN  Source-BEB
192.0.2.10   233.252.0.1    16300001   10     el2
192.0.2.10   233.252.0.2    16300002   20     el2
192.0.2.10   233.252.0.3    16300003   10     el2
192.0.2.10   233.252.0.4    16300004   20     el2
192.0.2.10   233.252.0.5    16300005   10     el2
192.0.2.10   233.252.0.6    16300006   20     el2
192.0.2.10   233.252.0.7    16300007   10     el2
192.0.2.10   233.252.0.8    16300008   20     el2
192.0.2.10   233.252.0.9    16300009   10     el2
192.0.2.10   233.252.0.10   16300010   20     el2
Total Number of SPBM IP MULTICAST ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vlan 501
             Id
Switch:1# show isis spbm ip-multicast-route vsn-isid 5010
SPBM IP-multicast ROUTE INFO - VLAN ID : 501, VSN-ISID : 5010
192.0.2.1      233.252.0.2    16300002      20    el2
192.0.2.1      233.252.0.3    16300003      10    el2
192.0.2.1      233.252.0.4    16300004      20    el2
192.0.2.1      233.252.0.5    16300005      10    el2
192.0.2.1      233.252.0.6    16300006      20    el2
192.0.2.1      233.252.0.7    16300007      10    el2
192.0.2.1      233.252.0.8    16300008      20    el2
192.0.2.1      233.252.0.9    16300009      10    el2
192.0.2.1      233.252.0.10   16300010      20    el2
Switch:1# show isis spb-mcast-summary
               SPB multicast - Summary
SCOPE    SOURCE           GROUP            DATA            LSP  HOST
I-SID    ADDRESS          ADDRESS          I-SID     BVID  FRAG NAME
5010     192.0.2.1       233.252.0.1     16300001  10    0x0  el2
5010     192.0.2.1       233.252.0.3     16300003  10    0x0  el2
5010     192.0.2.1       233.252.0.5     16300005  10    0x0  el2
5010     192.0.2.1       233.252.0.7     16300007  10    0x0  el2
5010     192.0.2.1       233.252.0.9     16300009  10    0x0  el2
5010     192.0.2.1       233.252.0.2     16300002  20    0x0  el2
5010     192.0.2.1       233.252.0.4     16300004  20    0x0  el2
5010     192.0.2.1       233.252.0.6     16300006  20    0x0  el2
5010     192.0.2.1       233.252.0.8     16300008  20    0x0  el2
5010     192.0.2.1       233.252.0.10    16300010  20    0x0  el2
