You can establish a threshold rate for receiving TC/TCN packets by configuring values for count and interval. If the threshold rate is exceeded, you receive a warning message. Use the following procedure to configure values for tc-receive-alarm-threshold count and tc-receive-alarm-threshold interval.
Configure count and interval values:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spanning-tree tc-receive-alarm-threshold count 3 Switch:1(config)#spanning-tree tc-receive-alarm-threshold interval 2
Display the alarm threshold configuration:
Switch:1#show spanning-tree tc-receive-alarm-threshold
Spanning Tree TC/TCN Rx Alarm Threshold Configuration
Interval : 2 minutes
Count : 3
Variable definitions
Use the data in the following table to use the tc-receive-alarm-threshold command.
Variable |
Value |
count <1-1000> |
Specifies the number of packets used to establish the threshold rate. The default is 2. |
interval <1-15> |
Specifies the time interval (in minutes) used to establish the threshold rate. The default is 1. |
