Multicast group trace tracks the data flow path of the multicast streams.
Display the multicast group trace for an IGMP snoop-enabled interface:
Switch:1>enable
Switch:1#show ip igmp snoop-trace
Snoop Trace - GlobalRouter
GROUP SOURCE IN IN OUT OUT TYPE
ADDRESS ADDRESS VLAN PORT VLAN PORT
203.0.113.17 192.0.2.7 1015 1/3 1015 1/35-1/40 ACCESS
203.0.113.20 192.0.2.7 1015 1/3 1015 1/35-1/40 ACCESS
203.0.113.19 192.0.2.7 1015 1/3 1015 1/35-1/40 ACCESS
203.0.113.18 192.0.2.7 1015 1/3 1015 1/35-1/40 ACCESS
The following table defines parameters for the show ip igmp snoop-trace command.
Variable |
Value |
group {A.B.C.D} |
Specifies the group IP address in the format a.b.c.d. |
source {A.B.C.D} |
Specifies the source IP address in the format a.b.c.d. |
