Use the show cli info command to display information about the CLI configuration. The syntax for this command is as follows.
show cli info
The following example shows sample output from the show cli info command.
Command output can vary across hardware models.
Switch:1#show cli info cli configuration more : true screen-lines : 23 telnet-sessions : 8 rlogin-sessions : 8 timeout : 900 seconds monitor duration: 300 seconds monitor interval: 5 seconds use default login prompt : true default login prompt : Login: custom login prompt : Login: use default password prompt : true default password prompt : Password: custom password prompt : Password: prompt : Switch
