Use the following procedure to configure connectivity associations (CA) using EDM.
You can configure MACsec on physical ports only. However, the physical ports can belong to an MLT trunk group that includes: Split MultiLink Trunking (SMLT), distributed MultiLink Trunking (DMLT), or Link aggregate group (LAG).
MACsec encryption and decryption algorithms follow either the AES-GCM-128 or the AES-GCM-256 standard, depending on the configured MAC-sec cipher suite. The default is the AES-GCM-128 standard.
- Select Chassis.
- Select the MACSec tab.
Select Insert.
- Select Apply.
MACSec Field Descriptions
Use the data in the following table to use the MACSec tab.
Name |
Description |
AssociationName |
Specifies a name for each connectivity association configured on the device. Tip:
Configure the Connectivity Association key name (CKN) in multiples of 4 characters to avoid MKA interoperability issues between VOSS switches and EXOS switches. For example, Macsecma (8 chararcters) or Macsecmka123 (12 characters) are valid, but Macsec (6 characters) is not valid. |
AssociationKey |
Specifies a pre-shared, connectivity association key associated with each connectivity association configured on the device. |
AssociationPortMembers |
Specifies the set of ports for which this connectivity association is associated. |
AssociationTxKeyParity |
Specifies Tx key parity using the following values:
