Use the following procedure to enable IPsec on a management interface.
By default, IPsec is disabled on the management interface.
This procedure applies to VSP 8600 Series only.
enable
configure terminal
interface mgmtEthernet <mgmt | mgmt2>
ipv6 ipsec enable
ip ipsec enable
Enable IPsec for IPv4 on the management interface:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface mgmtEthernet mgmt Switch:1(config-if)#ip ipsec enable
