Configure SLPP Guard on MLT and LAG ports to provide additional network loop protection.
SLPP Guard is disabled by default.
Switch:1(config-if)#slpp-guard enable Switch:1(config-if)#slpp-guard timeout 120
Variable definitions
Use the data in the following table to use the slpp-guard command.
Variable |
Value |
timeout <0 | 10–65535> |
Specifies the time period, in seconds, for which SLPP Guard disables the port. After the timeout period expires, the switch reenables the port. The timeout value can be 0 or a value ranging from 10 to 65535. With a value of 0, the port remains disabled until it is manually re-enabled. The default timeout value is 60 seconds. |
