Configure process-redirect messages to honor or ignore redirect messages for the management port. Redirect messages are visible only when Stateless Address Autoconfiguration is configured on switches capable of routing IPv6 traffic.
The default is disabled.
This procedure supports Layer 2 or Layer 3 process-redirect on VSP 8600 Series only.
Disable IPv6 forwarding.
Create an IPv6 interface.
Configure an IPv6 address.
enable
configure terminal
interface mgmtEthernet <mgmt | mgmt2>
ipv6 interface process-redirect
Switch:1(config-if)#ipv6 interface process-redirect
The following examples shows a sample output of the show ipv6 interface process-redirect command.
Switch:1#show ipv6 interface process-redirect
Process ICMP redirect status
IFINDX DESCR VLAN STATUS
64 PORT-mgmt 4092 Enabled
192 VLAN-5 5 Disabled
2050 VLAN-2 2 Disabled
