The following example shows how the VLAN Management Instance can be configured to share the same IP address as a routing port-based VLAN.
You can configure the VOSS VLAN first and then configure the VLAN Management Instance or vice versa. You can remove or readd the coexistence at anytime.
With the coexistence between VOSS routing stack and the VLAN Management Instance, packets sent to the VLAN Management Instance IP address must ingress the switch from a VLAN port (or contain the VLAN ID) associated with the VLAN Management Instance. The system does not route packets between the VOSS routing VLAN and the VLAN Management Instance.
vlan create 10 type port-mstprstp 0
vlan members add 10 1/1
interface vlan 10
ip address 192.0.2.0/24
exit
mgmt vlan 10
ip route 0.0.0.0/0 next-hop 192.0.2.1
enable
interface vlan 10
ipv6 interface address 2001:DB8::/32
ipv6 interface enable
exit
mgmt vlan 10
ipv6 address 2001:DB8::/32
ipv6 route 0::0/0 next-hop 2001::1
enable
