Use this procedure to move a vIST Leaf node pair from one DvR domain to another.
For vIST to work properly, both Leaf nodes must be in the same domain.
no router isis enable
no dvr leaf
Caution
Disabling DvR on a Leaf node in a vIST pair automatically removes all vIST configuration on that node, but not on the pair. The node on which DvR is disabled also loses its membership with the DvR domain and all the dynamic content learned from the Controllers in that domain.
When you re-enable DvR on the node, you must manually configure vIST on that node again.
Ensure that you configure both nodes as Leaf nodes and with the same domain ID.
dvr leaf <1–255>
dvr leaf virtual-ist {<A.B.C.D/X|<A.B.C.D> <A.B.C.D>} peer-ip {A.B.C.D} cluster-id <1–1000>
router isis enable
Consider two vIST peer Leaf nodes Switch1 (IP address 51.51.51.1) and Switch2 (51.51.51.2) that belong to a DvR domain (with domain ID 4), that you need to move to another domain (with domain ID 5).
View a summary of existing Leaf configuration on each node.
Switch1:1(config)#show dvr
DVR Summary Info
Domain ID : 4
Domain ISID : 16678220
Role : Leaf
My SYS ID : 00:00:72:54:44:00
Operational State : Up
GW MAC : 00:00:5e:00:01:25
Inband Mgmt Clip IP :
Virtual Ist local address : 51.51.51.1
Virtual Ist local subnet mask : 255.255.255.0
Virtual Ist peer address : 51.51.51.2
Virtual Ist cluster-id : 255
Virtual Ist ISID : 16677226
Switch2:1(config)#show dvr
DVR Summary Info
Domain ID : 4
Role : Leaf
My SYS ID : 00:00:72:55:45:00
Disable IS-IS globally on each Leaf node.
Switch1:1>en Switch1:1>conf t Enter configuration commands, one per line. End with CNTL/Z. Switch1:1(config)#router isis Switch1:1(config-isis)#no router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Switch2:1>en Switch2:1>conf t Enter configuration commands, one per line. End with CNTL/Z. Switch2:1(config)#router isis Switch2:1(config-isis)#no router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Disable DvR on each node. This automatically removes all vIST configuration on the node, but not on the vIST pair. The node also loses its membership with the DvR domain and all the dynamic content learned from the Controllers in that domain.
Switch1:1(config)#no dvr leaf
Switch2:1(config)#no dvr leaf
Configure each node as a DvR Leaf, with domain ID 5.
Switch1:1(config)#dvr leaf 5
Switch2:1(config)#dvr leaf 5
Configure vIST on each of the DvR Leaf nodes.
Switch1:1(config)#dvr leaf virtual-ist 51.51.51.1 peer-ip 51.51.51.2 cluster-id 255
Switch2:1(config)#dvr leaf virtual-ist 51.51.51.2 peer-ip 51.51.51.1 cluster-id 255
Enable IS-IS globally on each Leaf node.
Switch1:1(config)#router isis Switch1:1(config-isis)#router isis enable Switch1:1(config-isis)#exit Switch1:1(config)#
Switch2:1(config)#router isis Switch2:1(config-isis)#router isis enable Switch2:1(config-isis)#exit Switch2:1(config)#
View a summary of Leaf configuration on each node.
DVR Summary Info
Domain ID : 5
Domain ISID : 16678221
Role : Leaf
DVR Summary Info
Domain ID : 5
Role : Leaf
