Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
Use the following table to help you use the show interfaces GigabitEthernet error ospf command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes the output for the show interfaces GigabitEthernet error ospf command.
Parameters |
Description |
PORT NUM |
Indicates the port number. |
VERSION MISMATCH |
Indicates the number of version mismatches this interface receives. |
AREA MISMATCH |
Indicates the number of area mismatches this interface receives. |
AUTHTYPEMISMATCH |
Indicates the number of AuthType mismatches this interface receives. |
AUTH FAILURES |
Indicates the number of authentication failures. |
NET_MASK MISMATCH |
Indicates the number of net mask mismatches this interface receives. |
HELLOINT MISMATCH |
Indicates the number of hello interval mismatches this interface receives. |
DEADINT MISMATCH |
Indicates the number of dead interval mismatches this interface receives. |
OPTION MISMATCH |
Indicates the number of options mismatches this interface receives. |
