You can view the running configuration using the show command.
enable
show running-config
VSP-8284XSQ:1#show running-config Preparing to Display Configuration... # # # Thu Feb 05 18:38:02 2015 UTC # box type : VSP-8284XSQ # software version : 4.2.0.0_B004 (PRIVATE) # cli mode : CLI # # # #!end # config terminal # # #BOOT CONFIGURATION # boot config flags ftpd boot config flags telnetd # end boot flags auto-recover-delay 10 #CLI CONFIGURATION # telnet-access sessions 3 password password-history 3 # #SYSTEM CONFIGURATION # ip name-server primary 198.51.100.0 sys msg-control control-interval 30 sys msg-control # #
