Use this procedure to install one of the following:
certificate authority (CA) certificate
root CA certificate
subject certificate
Certificate Revocation List (CRL) file obtained offline from the CA
The following table defines parameters for the certificate install-file command.
Variable |
Definition |
offline-ca-filename WORD<1–80> |
Specifies the certificate authority (CA) file name obtained from the CA. |
offline-crl-filename WORD<1–80> |
Specifies the CRL file obtained from the CA. |
offline-root-ca-filename WORD<1–80> |
Specifies the root CA file name obtained from the CA. |
offline-subject-filename WORD<1–80> |
Specifies the subject certificate file name obtained from the CA. |
relaxed [pkcs12-password WORD<1-128>] Note:
Exception: not supported on VSP 8600 Series or XA1400 Series. |
Uses the relaxed mode for offline subject certificate installation for less restrictive consistency checks. You can also install a PKCS12 format certificate and secret key in relaxed mode. WORD<1-128> is the password to extract the PKCS12 container. If you do not include this parameter, the supported format is Distinguished Encoding Rules (DER). |
