A directed broadcast is a frame sent to the subnet broadcast address on a remote IP subnet. When you disable (or suppress) directed broadcasts on an interface, all frames sent to the subnet broadcast address for a local router interface are dropped. Disabling directed broadcasts protects hosts from possible denial-of-service (DOS) attacks. By default, this feature is enabled on the device.
Enable directed broadcast on a VLAN:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 2 Switch:1(config-if)#ip directed-broadcast enable
Display VLAN IDs with directed broadcast enabled:
Switch:1>show ip directed-broadcast vlan
Vlan Directed-Broadcast
VLAN ID DIRECTED-BROADCAST
2 true
The following table defines parameters for the ip directed-broadcast command.
Variable |
Value |
enable |
Enables the device to forward directed broadcast frames to the specified VLAN. The default setting for this feature is enabled. |
