Configure ports and MLT/SMLT interfaces for Endpoint Tracking.
- In Extreme Management Center, configure your third-party virtualization platform, and the RADIUS server used for Endpoint Tracking authentication. For information about configuring Extreme Management Center, see theExtreme Management Center documentation at https://www.extremenetworks.com/support/documentation/.
On the switch, add and configure the RADIUS server as configured in Extreme Management Center.
Enable Endpoint Tracking on ports or MLT/SMLT interfaces.
- Select Endpoint Tracking.
- Select the Interface tab.
- Select Insert.
- Select Port or Mlt, select the slot and port number or MLT ID, and select OK.
- Select InterfaceEnable.
- Select Insert.
- Select Apply.
What to do next
Configure Endpoint Tracking globally on the switch.
Interface Field Descriptions
Use the data in the following table to use the Interfaces tab.
| Name | Description |
InterfaceIndex |
Specifies the interface index of the selected port or MLT. |
InterfaceEnable |
Enables Endpoint Tracking on the selected port or MLT. |
