Disable SNMP by using the SNMP block flag. By default, SNMP access is enabled.
Switch:1>enable
Switch:1#configure terminal
Disable SNMP:
Switch:1(config)#boot config flags block-snmp
The following table defines parameters for the boot config flags command.
Variable |
Value |
block-snmp |
Configures the block SNMP flag as active. Use the no operator to remove this configuration. The default is off. To set this option to the default value, use the default operator with the command. |
