Configure the static MAC address parameters.
Configure a static MAC address of a VLAN:
Switch(config)# vlan mac-address-static 1 0x00:0x00:0x00:0x00:0x00:0x01 1/1
Variable definitions
Use the data in the following table to use the vlan mac-address-static command.
Variable |
Value |
<1-4059> |
<0x00:0x00:0x00:0x00:0x00:0x00> |
Indicates the MAC address. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
