Displaying local alarms
View local alarms to monitor alarm conditions.
Local alarms are raised and cleared by applications running on the switch. Local alarms are an automatic mechanism run by the system that do not require any additional user configuration. The raising and clearing of local alarms also creates a log entry for each event. Check alarms occasionally to ensure no alarms require additional operator attention.
For more information, see Alarm Database.
Display local alarms:
show alarm database
The switches that support SF cards display warning messages when SFIs are down.
Switch:1#show alarm database
       ALARM         EVENT          ALARM       ALARM                          CREATION  UPDATED         CLEARED
SLOT   ID            CODE           TYPE        STATUS        SEVERITY  FREQ   TIME      TIME            TIME        REASON
CP1  00300001.238    0x0000c5e7    DYNAMIC       SET          INFO       1      [11/17/15 06:42:55.928]  [11/17/15 06:42:55.928]  [--/--/-- --:--:--.---]  Link Down(1/47)
CP1  00300001.239    0x0000c5e7    DYNAMIC       SET          INFO       1      [11/17/15 06:42:55.946]  [11/17/15 06:42:55.946]  [--/--/-- --:--:--.---]  Link Down(1/48)
CP1  00300001.241    0x0000c5e7    DYNAMIC       SET          INFO       1      [11/17/15 06:42:55.971]  [11/17/15 06:42:55.971]  [--/--/-- --:--:--.---]  Link Down(1/50)
CP1  00400005        0x000045e5    DYNAMIC       SET          INFO       1      [11/17/15 06:43:41.929]  [11/17/15 06:43:41.929]  [--/--/-- --:--:--.---]  Sending Cold-Start Trap
