Use the following procedure to display all the SPB Multicast over Fabric Connect sources distributed to MSDP. This procedure is only valid on a Controller node.
Switch:1>show ip spb-pim-gw spbmc-source ============================================================================================ SPB-PIM-GW SPB Source ============================================================================================ SOURCE GROUP VRF ORIGINATOR -------------------------------------------------------------------------------------------- 10.0.0.1 240.0.0.1 GlobalRouter bcb-1 10.0.0.2 240.0.0.2 GlobalRouter bcb-2 10.0.0.3 240.0.0.3 GlobalRouter bcb-2 --------------------------------------------------------------------------------------------
Display the SPB Multicast over Fabric Connect from a specific VRF:
Switch:1>show ip spb-pim-gw spbmc-source vrf green ========================================================================================== SPB-PIM-GW Foreign Source ========================================================================================== SOURCE GROUP SPB-PIM-GW VRF OWNER CONTROLLER ------------------------------------------------------------------------------------------ 10.0.0.1 240.0.0.1 beb-1 green 47.17.0.1 bcb-2 10.0.0.2 240.0.0.2 beb-1 green static bcb-2 10.0.0.3 240.0.0.3 - green 47.17.0.2 bcb-2 ------------------------------------------------------------------------------------------
Display all the SPB Multicast over Fabric Connect sources advertised to MSDP with the originator value shown as a MAC address rather than a host name:
Switch:1>show ip spb-pim-gw spbmc-source vrf green spb-node-as-mac ============================================================================================= SPB-PIM-GW SPB Source ============================================================================================= SOURCE GROUP VRF ORIGINATOR --------------------------------------------------------------------------------------------- 10.0.0.1 240.0.0.1 green 00:0b:cb:00:00:c2 10.0.0.2 240.0.0.2 green 00:0b:cb:00:00:c2 10.0.0.3 240.0.0.3 green 00:0b:cb:00:00:c2 ---------------------------------------------------------------------------------------------
Variable definitions
The following table defines parameters for the show ip spb-pim-gw spbmc-source command.
Variable |
Value |
vrf WORD<0-16> |
Displays SPB originated sources for a specific VRF. |
vrfids WORD<0-512> |
Displays SPB originated sources for a range of VRF IDs.
Note:
Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
source {A.B.C.D} |
Displays information for a specific source IP address from SPB originated sources database. |
group {A.B.C.D} |
Displays information for a specific multicast group IP address from SPB originated sources database. |
originator WORD<0-32> |
Displays information for a specific originator host name from SPB originated sources database. |
spb-node-as-mac |
Displays the originator of SPB originated sources as a MAC address rather than a nickname. |
