You can monitor or apply the same configuration changes to more than one port by using the multiple port selection function. You can use the standard menu or the shortcut menu to edit the configuration settings for multiple ports.
Tip
A selected port shows a yellow outline around the port.
When you use the Enterprise Device Manager (EDM) embedded in the software, you can select a maximum of 24 ports.
No port limitation exists for COM users.
