Use the following procedure to enable DHCP Snooping globally. If DHCP Snooping is globally disabled, the switch forwards DHCP reply packets to all required ports, both trusted or untrusted.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip dhcp-snooping enable
The following table defines parameters for the ip dhcp-snooping command.
 Variable  |
 Value  |
 enable  |
 Enables or disables DHCP Snooping globally. By default, DHCP Snooping is disabled.  |
