Use IP forwarding (routing) on a global level so that the device supports routing. You can use the IP address of an interface for IP-based network management.
Activate IP forwarding and view the forwarding configuration:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf green
Switch:1(router-vrf)#ip routing
Switch:1(router-vrf)#show ip routing
IP - GlobalRouter
IP Forwarding is enabled
IP ECMP feature is disabled
Maximum ECMP paths number is 1
ECMP 1 pathlist :
ECMP 2 pathlist :
ECMP 3 pathlist :
ECMP 4 pathlist :
ECMP 5 pathlist :
ECMP 6 pathlist :
ECMP 7 pathlist :
ECMP 8 pathlist :
Gratuitous-Arp : enable
IP Alternative Route feature is enabled
IP More Specific Non Local Route feature is disabled
IP ICMP Unreachable Message is disabled
IP Supernetting is disabled
IP Icmp-echo-broadcast-request is enabled
IP Default TTL is 255 seconds
IP ARP life time is 360 minutes
IP Source Route Option is disabled
Variable definitions
Use the data in the following table to use the show ip routing command.
Variable |
Value |
vrf WORD<0-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF instance by VRF number. |
