Use the following procedure to display multicast routes ingressing on either SPB-PIM Gateway interfaces or SPB multicast interfaces.
The UPSTREAM_NBR field is populated only if the stream was learned across a spb-pim-gw interface, and the upstream neighbor is the PIM neighbor IP address toward the source. The PROT field equals spb-pim-gw when the stream‘s source is learned on a VLAN configured for protocol spb-pim-gw. If the stream's source is learned on a VLAN configured for spb-multicast, the PROT field equals spb.
Switch:1>show ip mroute route ============================================================================================ Mroute Route - GlobalRouter ============================================================================================ GROUP SOURCE SRCMASK UPSTREAM_NBR IF EXPIR PROT -------------------------------------------------------------------------------------------- 225.1.1.1 123.1.1.101 255.255.255.255 123.1.1.4 Vlan123 173 spb-pim-gw 1 out of 1 total mroute entries displayed
Variable definitions
The following table defines parameters for the show ip mroute route command.
| Variable | Value |
| vrf WORD<0-16> | Displays the multicast mroute information for a specific VRF name. |
| vrfids WORD<0-512> | Displays the multicast mroute information for a range of VRF IDs. Note:
                                     Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
