Configuring LACP on a VLAN
Use this procedure to configure LACP on a VLAN.
Important
Configuration at the global level overrides and resets all settings at the VLAN level.
Switch:1(config)#interface vlan 20
Switch:1(config-if)#lacp fast-periodic-time 2000
Switch:1(config-if)#lacp enable
Variable definitions
Use the data in the following table to use the lacp command.
| Variable | Value |
| aggr-wait-time <200–2000> | Configures the aggregation wait time (in milliseconds) globally. The default is 2000. |
| enable | Enables LACP for the VLAN. The default is disabled. |
| fast-periodic-time <200–20000> | Configures the fast periodic time (in milliseconds) globally for the VLAN. The default is 1000 ms. |
| slow-periodic-time <10000-30000> | Configures the slow periodic time globally for the VLAN. The default is 30000 ms. |
| smlt-sys-id 0x00:0x00:0x00:0x00:0x00:0x00 | Configures the LACP system ID globally. |
| system-priority <0-65535> | Configures the LACP system priority globally. |
| timeout-scale <2-10> | Configures a timeout scale for the VLAN. The default value is 3. The LACP timeout is equal to the slow periodic time or fast periodic time multiplied by the timeout-scale, depending how you configure the timeout-time variable. |
