Configure a port as trusted or untrusted to determine the Layer 2 QoS actions the switch performs. A trusted port (override disabled) honors incoming 802.1p bit markings. An untrusted port (override enabled) overrides 802.1p bit markings.
Enable DiffServ.
Variable definitions
Use the data in the following table to use the qos 802.1p-override command.
 Variable  |
 Value  |
 enable  |
 If you use this variable, the port overrides incoming 802.1p bits; if you do not use this variable, the port honors and services incoming 802.1p bits. The default is disable (Layer 2 trusted).  |
