Configure a prefix list to allow or deny specific route updates. A prefix list policy specifies route prefixes to match. After a match occurs, the system uses the route.
The prefix list contains a set of contiguous or noncontiguous routes. Reference prefix lists by name from within a routing policy.
Important
When you configure a prefix list for a route policy, add the prefix as a.b.c.d/32. You must enter the full 32-bit mask to exact a full match of a specific IP address.
You configure prefix lists on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode.
Configure a prefix-list. Display the prefix list.
Switch> enable
Switch# configure terminal
Switch(config)# ip prefix-list LIST1 192.0.2.1/255.255.255.0
Switch(config)# show ip prefix-list LIST1
                           Prefix List - GlobalRouter
        PREFIX           MASKLEN FROM TO
List 1    LIST1:
        192.0.1.2.1     24      24   24
1 Total Prefix List entries configured
Name Appendix for Lists Converted from Old Config:
@A=conv addr list, @N=conv net list, @NR=conv net list modified as range
Variable definitions
Use the data in the following table to use the ip prefix-list command.
| Variable | Value |
| {A.B.C.D/X} | Specifies the IP address and the mask in one of the following formats:
| ge <0–32> | Specifies the minimum length to match. Lower bound and higher bound mask lengths together can define a range of networks. |
| id <1-2147483647> | Specifies the Prefix list ID. |
| le <0–32> | Specifies the maximum length to match. Lower bound and higher bound mask lengths together can define a range of networks. |
| name WORD<1-64> | Renames the specified prefix list. The name length is 1–64 characters. |
| WORD<1-64> | Specifies the name for a new prefix list. |
Use the data in the following table to use the show ip prefix-list command.
| Variable | Value |
| {A.B.C.D} | Specifies the prefix to include in the command output. |
| vrf WORD<1-16> | Specifies the name of the VRF. |
| vrfids WORD<0-512> | Specifies the ID of the VRF and is an integer in the range of 0–512. |
| WORD<1-64> | Specifies a prefix list, by name, to use for the command output. |
Use the following table to use the show ip prefix-list command output.
| Variable | Value |
| PREFIX | Indicates the member of a specific prefix list. |
| MASKLEN | Indicates the prefix mask length in bits. |
| FROM | Indicates the prefix mask starting point in bits. |
| TO | Indicates the prefix mask endpoint in bits. |
