Use the following procedure to display IPsec information on an interface.
Display the IPsec status on a VLAN interface.
Switch:1>show ipsec interface vlan 22
VLAN Interface Policy Table
Vlan Interface Policy Name IPsec State Direction
22 AAA Enable both
22 tcp Enable both
22 icmp Enable both
The following table defines parameters for the show ipsec interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
mgmtethernet mgmt |
Identifies the interface as the management interface. Note:
Exception: only supported on VSP 8600 Series. |
loopback <1–256> |
Specifies the loopback interface. |
vlan <1-4059> |
Job aid
The following table describes the fields in the output for the show ipsec interface vlan command.
Parameter |
Description |
Vlan Interface |
Specifies the VLAN interface. |
Policy Name |
Specifies the IPsec policy that associates with the specific VLAN or VLANs. |
IPsec State |
Specifies whether the IPsec policy is enabled on the VLAN interface. |
Direction |
Specifies the policy direction. |
The following table describes the fields in the output for the show ipsec interface gigabitethernet command.
Parameter |
Description |
Interface |
Specifies the interface. |
Policy Name |
Specifies the IPsec policy that associates with the specific port or ports. |
IPsec State |
Specifies whether the IPsec policy is enabled on the interface. |
Direction |
The following table describes the fields in the output for the show ipsec interface mgmtethernet command.
This command applies to VSP 8600 Series only.
Parameter |
Description |
Interface |
Policy Name |
Specifies the IPsec policy that associates with the management port. |
IPsec State |
Direction |
The following table describes the fields in the output for the show ipsec interface loopback command.
Parameter |
Description |
LoopBack Interface |
Policy Name |
Specifies the IPsec policy that associates with the interface. |
IPsec State |
Direction |
