You can configure a service name for I-SIDs, loopback interfaces, and static routes. The service name can be configured before or after the I-SID is created for the following services:
- Layer 2 VSN
- Layer 3 VSN
- ELAN I-SID or Switched UNI I-SID
- ELAN transparent I-SID or Transparent UNI I-SID
- IPv4 and IPv6 static routes
- IPv4 and IPv6 loopback CLIP interface
The service name for I-SIDs does not support the following special characters: “ ” # $ % ‘ / [ \ ] ^ { | } ~ @.
By default, the service is named ISID-x, where x correlates to the I-SID number of the service.
Product Notice: For XA1400 Series, you can configure a service name for IPv4 static routes and IPv4 loopback CLIP interfaces only.
Product Notice: This procedure does not apply to VSP 8600 Series.
Use this procedure to provide a descriptive name for the Service Identifier (I-SID).
Switch:1>enable Switch:1#configure terminal Switch:1(config)#i-sid name 1 ExtremeServer1 Switch:1(config)#i-sid name 20 ExtremeServer7
View the configured I-SID names:
Switch:1(config)#show i-sid name
                          I-SID Name
I-SID           I-SID NAME                      TYPE
1               ExtremeServer1                  adminName
2               ExtremeServer2                  adminName
3               ExtremeServer3                  config adminName
4               ISID-4                          config
23              ISID-23                         config
25              ExtremeServer4                  config adminName
Total number of I-SID Name entries: 6.
            View the configured I-SID by number:
Switch:1#show i-sid name 1=======================================================================I-SID Name=======================================================================I-SID I-SID NAME TYPE-----------------------------------------------------------------------1 ExtremeServer1 adminName
Switch:1#show i-sid name 20=======================================================================I-SID Name=======================================================================I-SID I-SID NAME TYPE-----------------------------------------------------------------------20 ExtremeServer7 adminName
Use the data in the following table to use the i-sid name command.
| Variable | Value |
| <1-6777215> | Specifies the I-SID number. |
| WORD<1-64> Note:
                                 This parameter does not apply to all hardware platforms. | Specifies the name of the I-SID. The I-SID can be named before or after the I-SID is created. By default, for an I-SID in use, the service is named ISID-x, where x correlates to the I-SID number of the service. |
