BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use the following procedure to clear local and remote Bidirectional Forwarding Detection (BFD) session statistics for IPv4 or IPv6 interfaces.
The following table defines parameters for the clear ip bfd stats command.
| Variable | Value |
| vrf WORD<1-16> | Specifies a VRF instance by VRF name. |
| vrfids WORD<0-512> | Specifies a VRF or range of VRFs by ID. |
