If you cannot log on using Telnet or rlogin, perform the following steps.
Rlogin is only supported on the VSP 8600 Series.
Check whether the TACACS+ server configured on the platform has the correct IP address:
Switch:1>enable
Switch:1(config)#show tacacs
Global Status:
global enable : false
authentication enabled for : cli
accounting enabled for : none
authorization : disabled
User privilege levels set for command authorization : None
Server:
create :
Prio Status Key Port IP address Timeout Single Source SourceEnabled
Primary NotConn ****** 3 192.0.2.254 30 true 5.5.5.5 true
Backup NotConn ****** 47 198.51.100.1 10 false 0.0.0.0 false
Job Aid
The following table describes the fields in the output for the show tacacs command.
Name |
Description |
Global Status |
global enable |
Displays if the TACACS+ feature is enabled globally. |
authentication enabled for |
Displays which application is authenticated by TACACS+. The possibilities are CLI, web, or all. |
accounting enabled for |
Displays if accounting is enabled. You can only enable accounting for CLI. By default, accounting is not enabled. |
authorization |
Displays if authorization is enabled. |
User privilege levels set for command authorization |
Displays the privilege levels set for command authorization. When you configure command authorization for a particular level, all commands that you execute are sent to the TACACS+ server for authorization. The device can only execute the commands the TACACS+ server authorizes. The user privilege levels are:
Server |
Prio |
Displays the priority of the TACACS+ server. The switch attempts to use the primary server first, and the secondary server second. |
Status |
Displays the connection status between the server and the switch – connected or not connected. |
Key |
Displays as ****** instead of the actual key. The key is secret and is not visible. |
Port |
Displays the TCP port used to establish the connection to the server. The default port is 49. |
IP address |
Displays the IP address for the primary and secondary TACACS+ servers. |
Timeout |
Displays the period of time, in seconds, the switch waits for a response from the TACACS+ daemon before it times out and declares an error. The default is 10 seconds. |
Single |
Displays if a single open connection is maintained between the switch and TACACS+ daemon, or if the switch opens and closes the TCP connection to the TACACS+ daemon each time they communicate. The default is false, which means the device does not maintain the single open connection. |
Source Note:
Exception: only supported on VSP 8600 Series. |
Displays the fixed source IP address, if you configure one, for all outgoing TACACS+ packets. |
SourceEnabled Note:
Displays if the fixed source IP address is enabled for all outgoing TACACS+ packets. |
