Use the show ip pim neighbor command to display information about the neighboring routers configured with PIM-SM. The syntax for this command is as follows.
The following table shows the field descriptions for this command.
| Field | Description |
| INTERFACE | Indicates the interface number. |
| ADDRESS | Indicates the IP address of the PIM neighbor. |
| UPTIME | Indicates the elapsed time since this PIM neighbor last became a neighbor of the local router. |
| EXPIRE | Indicates the time that remains before this PIM neighbor times out. |
