Configure the metrics associated with the peer layer interface to control OSPF behavior. For finer control over port-specific metric speed, you can specify the metric speed when you configure OSPF on a port.
Enable OSPF globally.
Ensure that the interface uses an IP address.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
If Metrics field descriptions
Use the data in the following table to use the If Metrics tab.
 Name  |
 Description  |
 IP Address  |
 Specifies the IP address of the device used to represent a point of attachment in a TCP/IP internetwork.  |
 AddressLessIf  |
 Indicates addressed and addressless interfaces. This variable is 0 on interfaces with IP addresses and equals ifIndex for interfaces that have no IP address.  |
 TOS  |
 Specifies the type of service (TOS). The TOS is a mapping to the IP type of service flags as defined in the IP forwarding table management information base (MIB).  |
 Value  |
 Indicates the metric from the OSPF router to a network in the range.  |
 Status  |
 Specifies the status of the interface as active or not active. This variable is read-only.  |
