The toolbar buttons provide quick access to commonly used operational commands. The buttons that appear vary depending on the tab you select. However, the Apply, Refresh, and Help buttons are on almost every screen. Other common buttons are Insert and Delete. The following list detail the common toolbar buttons.
Apply—Use this button to execute all edits that you make.
Refresh—Use this button to refresh all data on the screen.
Help—Use this button to display online help that is context sensitive to the current dialog box.
Insert—Use this button to display a secondary dialog box related to the selected tab. After you edit the configurable parameters, click the Insert button in the dialog box. This causes a new entry to appear in the dialog box of the selected tab.
Delete—Use this button to delete a selected entry.
The following figure shows a sample toolbar.
