Use this procedure to specify a nickname allocation range for Dynamic Nickname Assignment.
You must disable Dynamic Nickname Assignment before you can change the nickname allocation range.
Configure a nickname allocation range:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spbm nick-name server range b
Dynamic Nickname Assignment configuration values and their associated behavior are shown in the following output from the show spbm command:
Switch:1>show spbm
spbm : enable
ethertype : 0x8100
nick-name server : disable
nick-name allocation : static
nick-name server range : B.00.00-B.FF.FF
Configure a nickname allocation prefix:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spbm nick-name server prefix C.30.00
The following table defines parameters for the spbm nick-name server command.
Variable |
Value |
prefix x.xx.xx |
Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default nickname allocation range is A.00.00-A.FF.FF. |
range <a-f> |
Specifies the nickname server allocation range. The default range is a (A.00.00 to A.FF.FF). |
