Use this procedure to view the LLDP local port information.
- Click LLDP.
- Click the Local Port tab.
Local port field descriptions
Use the data in the following table to use the Local Port tab.
| Name | Description |
| PortNum | Indicates the port number. |
| PortIdSubType | Indicates the type of port identifier.
| PortId | Indicates the identifier associated with the port, on the local system. |
| PortDesc | Indicates the description of the port, on the local system. |
