Use the following procedure to display information about IPFIX flows. You can display information for all IPFIX flows, or you can specify a single IPFIX flow and display additional information about that flow.
Display all IPFIX flows:
Switch:1>show ip ipfix flows
IPFIX Flows
Source Destination Source Destination Protocol In
IP IP Port Port Port
192.0.2.1 198.51.100.1 63 63 UDP 1/17
203.0.113.2 203.0.113.1 63 63 UDP RX-NNI
Display information about a specific IPFIX flow:
Switch:1>#show ip ipfix flows source-addr 203.0.113.2 dest-addr 203.0.113.1 s 63 d 63 p udp in-port rx-nni
IPFIX Flows
Source IP/ Src Port/ Protocol/ Start Time/ Byte Count/
Destination IP Dest Port In Port Observation Time Packet Count
203.0.113.2 63 UDP Tue Apr 09 06:48:57 2019 UTC 352376
203.0.113.1 63 RX-NNI Tue Apr 09 06:49:49 2019 UTC 5182
The following table defines parameters for the show ip ipfix flows command.
Variable |
Value |
dest-addr {A.B.C.D} |
Specifies an IP address for the flow destination. |
dest-port <1-65535> |
Specifies a value for the destination port. |
in-port <rx-nni | {slot/port[/sub-port]}> Note:
Exception: only supported on VSP 7400 Series. |
Specifies the port that learns the flow. |
in-vlan <1-4095> Note:
Exception: only supported on 5520 Series. |
Specifies an ingress VLAN ID for the flow. |
in-vrf <0-511> Note:
Specifies an ingress VRF ID for the flow. |
ip-ttl <0-255> Note:
Specifies the IP time-to-live (TTL) for the flow. |
protocol {udp|tcp} |
Specifies the transport protocol. |
source-addr {A.B.C.D} |
Specifies an IP address for the flow source. |
source-port <1-65535> |
Specifies a value for the source port. |
untagged Note:
Specifies ingress untagged flows. |
