Use the following procedure to display IPsec security association information.
Display information on IPsec security association policies:
Switch:1>enable
Switch:1#show ipsec sa all
IPSEC Security Association Table
sa-name: ospf1
key-Mode: manual
Encap protocol: ESP
SPI Value: 9
Encrypt Algorithm: 3dec-cbc
Encrypt-key: 52fb29f723b0800870dc83e3
Encrypt-key-Len: 24
Auth Algorithm: hmac-md5
Auth-key: 123456789abcdef0
Auth-key-Len: 16
Mode: transport
Lifetime-Sec: 1000
Lifetime-Byte: 20000
Switch:1#show ipsec sa name ospf1
sa-name: ospf1
key-Mode: manual
Encap protocol: ESP
SPI Value: 9
Encrypt-key-Len: 24
Auth-key-Len: 16
Mode: transport
Lifetime-Sec: 1000
Switch:1#show ipsec sa-policy
SA POLICY TABLE
Policy Name Security Association
ospf1 ospf1
The following table defines parameters for the show ipsec sa command.
Variable |
Value |
all |
Displays all security associations. |
name WORD<1–32> |
Displays a specific security association based on name. |
Use the data in the following table to use the show ipsec command.
Variable |
Value |
sa-policy |
Displays all security associations linked to a specific policy. |
Job aid
The following table describes the fields in the output for the show ipsec sa all and show ipsec saname commands.
Parameter |
Description |
sa-name |
Specifies all of the IPsec security association names. |
key-Mode |
Specifies the key mode as manual or automatic. The default is automatic. |
Encap protocol |
Specifies the encapsulation protocol. |
SPI Value |
Specifies the SPI value, which is a tag added to the IP header. For IPsec to function, each peer must have the same SPI value configured on both peers for a particular policy. |
Encrypt Algorithm |
Specifies the encrypt algorithm as one of the following:
Encrypt-key |
Specifies the encrypt-key parameter for the authentication key
in either:
Encrypt-key-Len |
Specifies the key length value in a string from 1 to 256 characters. The default KeyLength is 128. |
Mode |
Specifies the mode value as one of the following:
The default is transport mode. |
Lifetime-Sec |
Specifies the lifetime value in seconds. The default is 28800. |
Lifetime-Byte |
Specifies the lifetime value in bytes. The default is 4294966272. |
The following table describes the fields in the output for the show ipsec sa-policy command.
Parameter |
Description |
Policy Name |
Specifies the IPsec policy name. |
Security Association |
Specifies the security association name. |
