Configuring ARP ACEs
Use ACE Address Resolution Protocol (ARP) entries to ensure the filter looks for ARP requests or responses.
You cannot configure ARP attributes for IPv6 filters.
- The ACL exists.
- The ACE exists.
Variable definitions
Use the data in the following table to use the filter acl ace arp command.
| Variable | Value |
| <acl-id> | Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
| <ace-id> | Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
| operation eq <arprequest|arpresponse> | Specifies the type of ARP operation to filter: arpRequest or arpResponse. |
