Use the following procedure to create and configure an IKE Phase 1 profile.
- Click IKE.
- Click the Profile tab.
- Click Insert.
- In the Name field, type a profile name.
- Complete the remaining optional configuration to customize the policy.
- Click Insert.
IKE profile field descriptions
Use the data in the following table to use the tab.
| Name | Description |
| Name | Specifies the name of the profile. |
| HashAlgorithm | Specifies the hash algorithms that can be used during IKE Phase 1 SA negotiation. The default value is sha256. |
| EncryptionAlgorithm | Specifies the encryption algorithms that can be used during IKE Phase 1 SA negotiation. The default value is aesCbc. |
| EncryptKeyLen | Specifies the key length that should be used during IKE Phase 1 SA negotiation. The default value is 128. |
| DHGroup | Specifies the Diffie-Hellman groups that can be used during IKE Phase 1 SA negotiation. The default value is mod1024. |
| ExchangeMode | Specifies the IKE Phase 1 negotiation mode. The default value is main. |
| LifetimeSeconds | Specifies the amount of time for which an IKE Phase 1 SA can remain valid during IKE Phase 1 negotiation. A value of 0 means no the SA always remains valid. The default value is 86400 seconds. |
